Shared High Level Analyzers (HLAs)
EditUsage: High Level Analyzers Can be installed from within Logic 2 by navigating to ‘Extensions’ in the right hand menu and selecting ‘install’ on the extension of your choice. The extensions are listed alphabetically.
Version: 0.0.1
Author: Mark “Cool Guy” Garrison
Description: A test utility for C++ analyzers
Extensions:
- FrameV2 Tester: Type: HighLevelAnalyzer
Text Messages ★ 6
Version: 0.1.4
Author: Mark Garrison
Description: Merge multiple frames into a single frames based on delimiters and packet timeout
Extensions:
- Text Messages: Type: HighLevelAnalyzer
Seesaw Toolkit ★ 0
Version: 0.1.0
Author: Rani Horev
Description: Parse AdaFruit’s Seesaw modules data
Extensions:
- Seesaw Reader: Type: HighLevelAnalyzer
- I2C Filter: Type: HighLevelAnalyzer
Gyro L3G4200D ★ 1
Version: 0.0.1
Author: Ryan Huffman
Description:
Extensions:
- Gyro L3G4200D: Type: HighLevelAnalyzer
Joy FeatherWing ★ 0
Version: 0.0.1
Description:
Extensions:
- Joy FeatherWing: Type: HighLevelAnalyzer
Hex-Dec-Char To Terminal ★ 2
Version: 0.0.2
Author: Jared Reabow
Description: Output Hex,Dec or Char to terminal and frames, with delimiter processing to format output based on specified HEX,DEC or CHAR delimiter.
Extensions:
- Hex to Terminal: Type: HighLevelAnalyzer
I2C Transactions ★ 4
Version: 1.1.0
Description: Converts I2C bytes into 1 frame per transaction
Extensions:
- I2C Transactions: Type: HighLevelAnalyzer
Cortex TPIU ★ 2
Version: 0.0.8
Author: James G. Smith
Description: ARM Cortex TPIU ITM/DWT utilities
Extensions:
- TPIU: Type: HighLevelAnalyzer
- ITMDWT: Type: HighLevelAnalyzer
I2C Demo ★ 2
Version: 0.0.1
Author: Mark
Description: A quick demo
Extensions:
- I2C Demo: Type: HighLevelAnalyzer
SPITFP ★ 1
Version: 2.0.8
Author: Erik Fleckstein [email protected]
Description: Tinkerforge SPITFP high level analyzer.
Extensions:
- SPITFP: Type: HighLevelAnalyzer
USB PD (Biphase Mark Code) ★ 24
Version: 0.0.1
Author: Mark
Description: Decodes USB PC CC Pin with BMC encoding
Extensions:
- USB PD (Biphase Mark Code): Type: HighLevelAnalyzer
TUSB422 ★ 4
Version: 0.0.1
Description:
Extensions:
- TUSB422: Type: HighLevelAnalyzer
SDMMC from SPI ★ 9
Version: 20.7.3
Author: Tim Kostka [email protected]
Description: Saleae Logic 2.x high level analyzer for SD/MMC communication
Extensions:
- SDMMC from SPI: Type: HighLevelAnalyzer
SPI transaction framer ★ 2
Version: 1.0.3
Author: Jonathan Reichelt Gjertsen
Description: Merges SPI frames into transactions based on when the Enable line is active
Extensions:
- SPI transaction framer: Type: HighLevelAnalyzer
Jacdac Serial ★ 2
Version: 0.0.3
Author: Michal Moskal
Description: Decode Jacdac single-wire-serial packets
Extensions:
- Jacdac Serial: Type: HighLevelAnalyzer
DJI T16 M BUS Decoder ★ 0
Version: 0.0.1
Description: Designed for decoding agras T16 signals
Extensions:
- DJI T16 M BUS Decoder: Type: HighLevelAnalyzer
COBS and COBS/R decoding ★ 1
Version: 1.0.0
Description: Decodes COBS or COBS/R encoded serial data.
Extensions:
- COBS decoder: Type: HighLevelAnalyzer
- COBS/R decoder: Type: HighLevelAnalyzer
SPI Flash ★ 22
Version: 1.0.0
Author: Scott Shawcroft for Adafruit
Description: Annotate common SPI flash commands
Extensions:
- SPI Flash: Type: HighLevelAnalyzer
Concatenator ★ 1
Version: 0.1.5
Author: Dennis Bemmann
Description: Concatenates single bytes to multi-byte messages
Extensions:
- Concatenator: Type: HighLevelAnalyzer
I2C 8-bit Address Display ★ 1
Version: 0.0.2
Description: Converts I2C 7-Bit Addresses as 8 bit with R/W bit
Extensions:
- I2C 8-bit Address Display: Type: HighLevelAnalyzer
RFM69 Decoder ★ 0
Version: 0.1.2
Author: Alex M.
Description: Decodes register reads and writes to the RFM69 radio.
Extensions:
- RFM69 Decoder: Type: HighLevelAnalyzer
PCF8583 ★ 1
Version: 0.2.2
Author: Harald Kubota
Description: Decoding PCF8583 Time and Date for Saleae Logic 2
Extensions:
- pcf8583: Type: HighLevelAnalyzer
UART HCI Decoder ★ 2
Version: 0.1.0
Author: Brian Gomberg
Description: Decodes HCI packets sent over UART
Extensions:
- HCI: Type: HighLevelAnalyzer
printf parse text to terminal ★ 0
Version: 1.1.0
Author: Agknaton Bottenberg
Description: Extract ASCII text from bus protocols and simply print it to the terminal
Extensions:
- printf parse text to terminal: Type: HighLevelAnalyzer
Sequence search ★ 1
Version: 0.0.1
Author: Tomáš Poruba
Description: Sequence search in ascii, dec, hex input format from selected analyzer
Extensions:
- Sequence search: Type: HighLevelAnalyzer
Dynamixel V2 Decoder ★ 1
Version: 1.0.4
Author: Thomas Jeantet
Description: Decodes Dynamixel protocol V2
Extensions:
- DynamixelV2: Type: HighLevelAnalyzer
IO-Link ★ 11
Version: 1.1.0
Author: Sebastian Herber
Description: Decode IO-Link frames from the C/Q signal
Extensions:
- IO-Link: Type: HighLevelAnalyzer
DFPlayerMini Decoder ★ 0
Version: 0.0.2
Author: Arnix
Description: Decode serial Rx/Tx data for DFPlayer Mini
Extensions:
- DFPlayerMini Decoder: Type: HighLevelAnalyzer
Serial Wombat Protocol Analyzer ★ 0
Version: 1.1.0
Author: Broadwell Consulting Inc
Description: Decodes 8 Byte Serial Wombat Protocol I2C And UART Frames
Extensions:
- Serial Wombat Protocol Analyzer: Type: HighLevelAnalyzer
LSS Bus Analyzer ★ 2
Version: 0.0.1
Author: Colin MacKenzie
Description: Analyze data on an RobotShop Lynxmotion LSS bus.
Extensions:
- LSS Bus Analyzer: Type: HighLevelAnalyzer
XpressNet ★ 0
Version: 0.0.2
Author: Sebastian Knackstedt, UtFryslan
Description: This extension provides support for XpressNet, a communication protocol in model railroads. Works only with an Async-Serial analyzer as base. WIP.
Extensions:
- XpressNet: Type: HighLevelAnalyzer
NEC Decoder ★ 6
Version: 1.2.0
Author: Joey Murphy
Description: Decodes IR Remote NEC codes
Extensions:
- NEC Decoder: Type: HighLevelAnalyzer
Time Delimiter Chunking ★ 0
Version: 0.0.1
Author: nplus11
Description: Merge multiple frames by time
Extensions:
- Time Delimiter Chunking: Type: HighLevelAnalyzer
BQ25150 Linear Battery Charger ★ 0
Version: 1.0.0
Author: Lena Voytek
Description: I2C interface analyzer for the TI BQ25150 Linear Battery Charger
Extensions:
- BQ25150 Linear Battery Charger: Type: HighLevelAnalyzer
F.Port decoder ★ 2
Version: 0.0.1
Author: Mykolas Juraitis
Description: Decodes FrSKY F.Port protocol
Extensions:
- F.Port decoder: Type: HighLevelAnalyzer
Swiss Air Data ★ 2
Version: 1.1.0
Author: Simtec AG
Description: Decodes frame sent by a swiss air data computer
Extensions:
- Swiss Air Data: Type: HighLevelAnalyzer
SaleaePacketParser ★ 1
Version: 1.0.4
Author: Super Enot
Description: This is a Saleae Logic custom high level analyzer that allows you to search and mark specific packets.
Extensions:
- SaleaePacketParser: Type: HighLevelAnalyzer
I2C Device Finder ★ 1
Version: 0.0.1
Author: Jędrzej Szczepaniak
Description: Simple addon to mark address messages for choosen device address
Extensions:
- I2C Device Finder: Type: HighLevelAnalyzer
Unsigned Integer Display ★ 0
Version: 0.0.1
Author: Tim Reyes
Description: Converts any byte array input fields to integer fields.
Extensions:
- Unsigned Integer Display: Type: HighLevelAnalyzer
MSTP ★ 0
Version: 0.0.1
Author: Hubert Bossy
Description:
Extensions:
- **MSTP **: Type: HighLevelAnalyzer
SocketCAN ★ 2
Version: 0.0.1
Author: Matheus Eduardo Garbelini
Description: Send decoded can frames to socket can
Extensions:
- SocketCAN: Type: HighLevelAnalyzer
LIN Data ★ 4
Version: 1.0.3
Author: ma.lwa.re
Description: LIN Data is a high-level extension for the LIN protocol.
Extensions:
- LIN Data: Type: HighLevelAnalyzer
Si4430/31/32 Protocol Decoder ★ 0
Version: 0.0.1
Author: Michael S.
Description: Decodes communication between a host MCU and a Si4430/31/32 ISM Transceiver. Works on top of the SPI analyzer
Extensions:
- Si4430/31/32 Protocol Decoder: Type: HighLevelAnalyzer
Dynamixel Servo HLA ★ 2
Version: 0.0.1
Author: KurtE
Description: HLA for Robotis Dynamixel Servos
Extensions:
- Dynamixel Servo HLA: Type: HighLevelAnalyzer
Re Search ★ 0
Version: 1.3.1
Author: Peter Jaquiery
Description: Match text in async serial logging
Extensions:
- ReSearch: Type: HighLevelAnalyzer
Aneng Q10 LCD Driver SPI Analyzer ★ 0
Version: 1.0.0
Author: Rejdukien
Description: Analyzing SPI communication between DTM0660L and the unmarked LCD driver; Every single segment is simply encoded as bitflag.
Manufacturer seems to be ZOYI/Zotek, Model ZTY.
Extensions:
- Aneng Q10 LCD Driver SPI Analyzer: Type: HighLevelAnalyzer
MDB-HLA - Multi-Drop-Bus High-Level Analyzer ★ 1
Version: 0.5.0
Author: Amir El Sewisy (IoTrio GmbH)
Description: High-Level Analyzer for MDB (Multi-Drop-Bus) based on 9-bit UART packets used by vending machine controllers and peripherals.
Extensions:
- MDB-HLA: Type: HighLevelAnalyzer
u-blox UBX ★ 6
Version: 1.0.5
Author: SparkFun & Contributors
Description: A Logic2 High Level Analyzer for the u-blox UBX protocol. Also supports NMEA and RTCM.
Extensions:
- SparkFun_u-blox_UBX_HLA: Type: HighLevelAnalyzer
usb4_sbu ★ 0
Version: 0.0.1
Author: eznob
Description:
Extensions:
- tbt3_sbu: Type: HighLevelAnalyzer
W5500 ★ 0
Version: 0.0.2
Author: Alex Martens
Description: W5500 SPI bus decoder
Extensions:
- W5500: Type: HighLevelAnalyzer
Socket Transport ★ 4
Version: 1.0.1
Author: Michael Leonard
Description: Send and receive analyzer data over a network socket (routed to localhost by default).
Extensions:
- Socket Transport: Type: HighLevelAnalyzer
REV Hub Serial Protocol Analyzer ★ 0
Version: 1.0.2
Author: REV Robotics
Description:
Extensions:
- REV Hub Serial Protocol Analyzer: Type: HighLevelAnalyzer
Playstation Decoder ★ 1
Version: 0.0.1
Author: Verox Zik
Description: Decode SPI protocol used between Playstation console and controller.
Extensions:
- Playstation Decoder: Type: HighLevelAnalyzer
Version: 1.0.2
Description:
Extensions:
SPI Transceiver ★ 0
Version: 1.0.0
Author: Yaniv Wolfus
Description: Analzyer for SPI transceivers. Currently supports the stm32wl’s transceiver.
Extensions:
- SPI Transceiver: Type: HighLevelAnalyzer
Smart Battery System Analyzer ★ 1
Version: 0.0.1
Author: René Moll
Description: Decodes the Smart Battery Data (rev 1.1)
Extensions:
- Smart Battery System Analyzer: Type: HighLevelAnalyzer
DIN66348 ★ 0
Version: 1.2.0
Author: Stefan Seegel
Description: HLA for DIN 66348 measurement bus
Extensions:
- DIN66348: Type: HighLevelAnalyzer
MCP23017 ★ 0
Version: 1.0.0
Description: Decodes MCP23017 I2C traffic.
Extensions:
- MCP23017: Type: HighLevelAnalyzer
CRSF ★ 22
Version: 0.5.2
Author: Max Gröning
Description: Crossfire decoder for R/C protocol as used by TBS Crossfire, Tracer or ExpressLRS
Extensions:
- CRSF: Type: HighLevelAnalyzer
I2C_STUSB4500 ★ 0
Version: 0.0.1
Author: Paulvha
Description: Analyse the I2C communication STUSB4500
Extensions:
- I2C_STUSB4500: Type: HighLevelAnalyzer
SHTC3 Transactions ★ 0
Version: 1.2.4
Author: Dragos Circa
Description: Converts I2C bytes into SHTC3 response
Extensions:
- SHTC3 Transactions: Type: HighLevelAnalyzer
MCP9600 ★ 1
Version: 0.0.2
Author: paulvha
Description: MCP9600 I2c communication
Extensions:
- MCP9600: Type: HighLevelAnalyzer
NRF24L01(+) ★ 1
Version: 0.2.2
Author: Jan-Philipp Roslan
Description: Decoder for Nordic Semiconductor NRF24L01(+) transceivers
Extensions:
- NRF24L01: Type: HighLevelAnalyzer
Semtech SX128x SPI in ★ 2
Version: 0.0.1
Author: Risto Kõiva
Description: Semtech SX128x SPI IN HLA
Extensions:
- SX128x SPI in: Type: HighLevelAnalyzer
Semtech SX128x SPI out ★ 2
Version: 0.0.1
Author: Risto Kõiva
Description: Semtech SX128x SPI OUT HLA
Extensions:
- SX128x SPI out: Type: HighLevelAnalyzer
SHTP+SH2 ★ 3
Version: 0.0.2
Author: Roberts Kalnins
Description: SHTP parser with SH2 interpretation
Extensions:
- SH2: Type: HighLevelAnalyzer
- SHTP: Type: HighLevelAnalyzer
BM13xx protocol decoder ★ 9
Version: 0.7.0
Author: GPTechinno
Description: BM13xx protocol decoder
Extensions:
- BM13xx protocol decoder: Type: HighLevelAnalyzer
IOEX6416 ★ 0
Version: 1.0.0
Author: NemesisXB
Description: Decodes PCAL6416|PI4IOE5V6416|TCA6416 I2C traffic.
Extensions:
- IOEX6416: Type: HighLevelAnalyzer
sc16is7x0 decoder ★ 0
Version: 0.0.1
Author: Georges Palauqui - Leroy Automation
Description: sc16is7x0 SPI bus decoder
Extensions:
- sc16is7x0 decoder: Type: HighLevelAnalyzer
Parade Technologies TrueTouch Protocols ★ 0
Version: 0.7.0
Author: Parade Technologies
Description: Parade Technologies TrueTouch protocols (PIP1, PIP2, PIP3, HID-I2C)
Extensions:
- Parade Technologies: Type: HighLevelAnalyzer
23LC512 SPI ★ 0
Version: 0.0.3
Author: iAchieved.it
Description: Decode 23LC512 SPI
Extensions:
- 23LC512 SPI: Type: HighLevelAnalyzer
PD3.0 Analyzer ★ 1
Version: 0.0.6
Author: Eugene Yeh
Description: PD3.0 Analyzer
Extensions:
- PD3.0 Analyzer: Type: HighLevelAnalyzer
Carriage Return to Line Feed Converter ★ 0
Version: 0.0.1
Description: This HLA prints serial results to the terminal, replacing \r with \n. It does not produce output frames.
Extensions:
- Carriage Return to Line Feed Converter: Type: HighLevelAnalyzer
WPC Qi HLA ★ 0
Version: 1.0.0
Author: Richard Sim <@richard-sim>
Description: Decodes WPC Qi protocol packets from raw bytes generated by the Qi-Analyzer low-level analyzer (separate installation required, see README.md)
Extensions:
- WPC Qi HLA: Type: HighLevelAnalyzer
R/C Protocol Analyzer ★ 0
Version: 0.0.1
Author: Vincent D’Alessandro
Description: Analyzer for R/C bus protocols
Extensions:
- R/C Protocol: Type: HighLevelAnalyzer
Semtech SX127x SPI ★ 2
Version: 0.0.1
Author: Sebasthian Ogalde
Description: Semtech SX127x SPI
Extensions:
- SX127x SPI: Type: HighLevelAnalyzer
HLA-ccTalk ★ 0
Version: 0.9.5
Author: Rachid AKKOUCHE
Description: ccTalk High Level Analyser
Extensions:
- HLA-ccTalk: Type: HighLevelAnalyzer
SPI MEMORY ANALYZER ★ 0
Version: 0.0.2
Author: Thomas Poms
Description: Analyzes SPI memory frames
Extensions:
- SPI Memory Analyzer: Type: HighLevelAnalyzer
Futaba SBUS ★ 5
Version: 0.0.2
Author: Pascal HEUDE
Description: Decode the Futaba SBUS protocol
Extensions:
- Futaba SBUS: Type: HighLevelAnalyzer
VPC3 SPI ANALYZER ★ 0
Version: 0.0.1
Author: Thomas Poms
Description: Analyzes VPC3 SPI frames
Extensions:
- VPC3 SPI Analyzer: Type: HighLevelAnalyzer
Texas Instruments Daisy Chain Protocol ★ 0
Version: 0.2.0
Author: Zoltan Dolensky
Description: Isolated daisy chain protocol for BQ79600/BQ7961x/BQ7971x
Extensions:
- Texas Instruments Daisy Chain Protocol: Type: HighLevelAnalyzer
Spektrum Bootloader and SG3 Decoder ★ 3
Version: 0.0.1
Author: Anthony Casagrande
Description: Decode Spektrum Programmer and iX12/14/20 SG3 UART communications of compatible Surface and Air Transmitter and Receivers.
Extensions:
- Spektrum Bootloader and SG3 Decoder: Type: HighLevelAnalyzer
Digi XBee ★ 0
Version: 1.0.1
Author: S. Seegel
Description: Analyze API frames (API mode 1 & 2)
Extensions:
- Digi XBee: Type: HighLevelAnalyzer
EEPROM I2C to iHex converter ★ 0
Version: 0.1.1
Author: GPTechinno
Description: EEPROM I2C to iHex converter
Extensions:
- EEPROM I2C to iHex converter: Type: HighLevelAnalyzer
LM75a I2C protocol decoder ★ 0
Version: 0.1.0
Author: GPTechinno
Description: LM75a I2C protocol decoder
Extensions:
- LM75a I2C protocol decoder: Type: HighLevelAnalyzer
Texas Instrument - TRF7970A (SPI) ★ 8
Version: 1.0.0
Author: Benjamin Delpy (@gentilkiwi)
Description: High Level Analyzer for Texas Instrument TRF7970A NFC chip on SPI bus
Extensions:
- Texas Instrument - TRF7970A (SPI): Type: HighLevelAnalyzer
BM64 UART ★ 0
Version: 1.0.4
Author: SOUNDBOKS
Description: This analyzer will decode the BM64 Bluetooth module UART communication, consisting of communication in protocols such as HCI, ISDAP and the proprietary BM64 control protocol.
Extensions:
- BM64: Type: HighLevelAnalyzer
ISO7816_Hla ★ 0
Version: 0.0.1
Author: Romain Cognasse
Description:
Extensions:
- ISO7816_Hla: Type: HighLevelAnalyzer
CXPI Analyzer ★ 0
Version: 3.4.1
Author: Nikolay
Description: Анализатор CXPI
Extensions:
- CxpiAnalyzer: Type: HighLevelAnalyzer
smtc_sx126x ★ 1
Version: 1.1
Author: Wayne Roberts
Description: SX126x SPI parser
Extensions:
- smtc_sx126x: Type: HighLevelAnalyzer
I2C Smart Capture ★ 1
Version: 0.0.5
Author: Chengyu Chen
Description: Capture the specific I2C data, and result PASS & FAIL, Output Time period data
Extensions:
- I2C Smart Capture: Type: HighLevelAnalyzer
MCP2515-HLA ★ 1
Version: 0.0.1
Author: Adrian Gielniewski
Description: SPI interface analyzer for MCP2515 CAN controller
Extensions:
- MCP2515-HLA: Type: HighLevelAnalyzer
Spektrum Receiver Packet Analyzer ★ 0
Version: 0.0.2
Author: nbes4
Description: Decodes Spektrum (tm) remote receiver packets. Check out the README for more info.
Extensions:
- Spektrum Remote Receiver: Type: HighLevelAnalyzer
STMicroelectronics - ST25R3916 (SPI) ★ 5
Version: 1.0.0
Description: High Level Analyzer for STMicroelectronics ST25R3916 NFC chip on SPI bus
Extensions:
- STMicroelectronics - ST25R3916 (SPI): Type: HighLevelAnalyzer
TDA5235 ★ 0
Version: 1.0.0
Author: JFíla
Description:
Extensions:
- TDA5235: Type: HighLevelAnalyzer
Bitmain I2C protocol decoder ★ 0
Version: 0.1.0
Author: GPTechinno
Description: Bitmain I2C protocol decoder
Extensions:
- Bitmain I2C protocol decoder: Type: HighLevelAnalyzer
OSDP v2.2 ★ 0
Version: 0.2.0
Author: ARNik
Description: OSDP v2.2 analyzer
Extensions:
- OSDP v2.2: Type: HighLevelAnalyzer
JetiExBus ★ 1
Version: 0.0.1
Author: Markus Pfaff, P2L2.com
Description: Decodes JETImodel EX Bus protocol
Extensions:
- JetiExBus: Type: HighLevelAnalyzer
UfcPktParser ★ 0
Version: 0.0.1
Author: Elsa Forberger, Adit Kadepurkar
Description: Test
Extensions:
- UfcPktParser: Type: HighLevelAnalyzer
PD3.1 Analyzer ★ 5
Version: 0.0.7
Author: Eugene Yeh
Description: PD3.1 Analyzer
Extensions:
- PD3.1 Analyzer: Type: HighLevelAnalyzer
CRSF ★ 3
Version: 1.0.1
Author: Ansh Chawla(Original code by : Max Gröning)
Extensions:
NEC Decoder ★ 6
Version: 1.2.0
Author: Joey Murphy
Extensions:
cc1101 ★ 1
Version: 0.0.1
Author: Jeff Mathews
Description:
Extensions:
- saleae-cc1101: Type: HighLevelAnalyzer
Custom Data ★ 6
Version: 0.0.3
Author: Aaron Christiansen
Description: Describe and annotate custom data patterns
Extensions:
- CustomData: Type: HighLevelAnalyzer
UBM I2C Analyzer ★ 0
Version: 0.0.1
Author: Kyle Reynolds
Description: This is a High Level Analyzer for the UBM protocol run on I2C.
Extensions:
- UBM I2C Analyzer: Type: HighLevelAnalyzer
KNX Decoder ★ 0
Version: 0.0.1
Author: Alex Braun
Description: Decoding KNX telegram
Extensions:
- KNX Decoder: Type: HighLevelAnalyzer
CC1101 SPI Analyzer ★ 5
Version: 1.0.0
Author: Andrei Basarab
Description: SPI protocol analyzer for the Texas Instruments CC1101 RF Transceiver
Extensions:
- CC1101 SPI Analyzer: Type: HighLevelAnalyzer
Bluetooth HCI Utility ★ 0
Version: 0.0.1
Author: Nirav Agrawal
Description: Prepare & Forward Bluetooth HCI H4 Packets to Ellisys UDP HCI-Inject Interface
Extensions:
- Bluetooth HCI Inject to Ellisys: Type: HighLevelAnalyzer
CAN Message Concatenator ★ 0
Version: 0.0.1
Author: Evan Blum
Description: Smoosh together all the disparate parts of CAN messages
Extensions:
- CAN Message Concatenator: Type: HighLevelAnalyzer
NXP - PN532 (SPI) ★ 3
Version: 1.0.0
Description: High Level Analyzer for NXP PN532 NFC chip on SPI bus
Extensions:
- NXP - PN532 (SPI): Type: HighLevelAnalyzer
LANC decoder ★ 0
Version: 1.0.2
Author: miahi
Description:
Extensions:
- LANC decoder: Type: HighLevelAnalyzer
GTL interface decoder ★ 0
Version: 2024.12.0
Author: Renesas Electronics Corporation
Description: Decoder for the GTL interface used by Renesas Smartbond devices
Extensions:
- GTL decode: Type: HighLevelAnalyzer
RDM ★ 0
Version: 0.0.1
Author: Bartel
Description: RDM: Remote Device Management - ANSI E1.20
Extensions:
- RDM: Type: HighLevelAnalyzer
Blues Serial-Over-I2C Analyzer ★ 1
Version: 1.0.0
Author: Blues
Description: A High Level Analyzer for the Blues Serial-Over-I2C protocol
Extensions:
- Serial-Over-I2C Protocol: Type: HighLevelAnalyzer
Betaflight MSP ★ 2
Version: 1.5.0
Author: Steve Evans
Description: Betaflight MultiWii Serial Protocol (MSP)
Extensions:
- Betaflight MSP: Type: HighLevelAnalyzer
Fast Serial Interface ★ 0
Version: 0.0.1
Author: shy coder
Description:
Extensions:
- Fast Serial Interface: Type: HighLevelAnalyzer
Tmag5170_SPI_decoder ★ 0
Version: 0.0.5
Author: Michał Malinowski
Description: Extension for analyzing protocol use by tmag5170 magnetic field sensor on spi bus
Extensions:
- Tmag5170_SPI_decoder: Type: HighLevelAnalyzer
I2C-PCA9685 ★ 0
Version: 0.0.2
Author: flo17
Description: High Level Analyzer for PCA9685 - I2C PWM Driver
Extensions:
- I2C-PCA9685: Type: HighLevelAnalyzer
STMicroelectronics - STWBC2-HB (serial) ★ 1
Version: 1.0.0
Author: Christopher Koch
Description: Logic 2 High-Level Analyzer for the STWBC2-HB wireless charging and power delivery chip.
Extensions:
- STWBC2-HB: Type: HighLevelAnalyzer
