1-Wire - Frame Format
EditOutput Frame Format
Frame Type: "reset"
| Property | Type | Description |
- Reset pulse
Frame Type: "presence"
- Presence Pulse
Frame Type: "rom_command"
description | str | read, skip, search, or match |
rom_command | bytes | The command byte |
- ROM command. This is the first command issued by the master after a presence pulse
Frame Type: "crc"
crc | bytes | The CRC byte |
- 8 bit CRC, last part of the 64 bit identifier
Frame Type: "family_code"
family | bytes | The family code, which is the first part of the 64 bit identifier |
- The family code of the device ID
Frame Type: "id"
id | int | 48 bit integer, taken from the center of the 64 bit identifier |
- The 48 bit device identifier
Frame Type: "data"
data | bytes | A single data byte |
- Data byte after the ROM command and identifier
Frame Type: "invalid_rom_command"
rom_command | bytes | The ROM command byte |
- Unknown ROM command
Frame Type: "alarm"
- Alarm search command
