LIN - Frame Format
EditOutput Frame Format
Frame Type: "no_frame"
| Property | Type | Description |
- undefined
- Inter-byte space
Frame Type: "header_break"
- undefined
- Header break
Frame Type: "header_sync"
- undefined
- Header sync
Frame Type: "header_pid"
protected_id | int | 6 bit protected Id |
- Protected identifier
Frame Type: "data"
data | int | Data byte |
index | int | Index, 0-8, of the data byte inside of the transaction |
Frame Type: "checksum"
checksum | int | LIN checksum |
- Checksum byte
Frame Type: "data_or_checksum"
- Unable to determine if this byte is a data byte or a checksum. It is technically valid as both. This occurs if a a data byte, at index N, is equal to what the CRC should be if the transaction is N-1 bytes.
