Binary and CSV Export Formats - 2025 Update
EditThe Logic 2 binary and CSV export file formats are being updated to support new Saleae products.
Existing products, including Logic 8, Logic Pro 8, and Logic Pro 16, still use the original binary export (version 0), however those will be updated to support the new export format soon.
Version 0 of the binary export, still in use for Logic 8, Logic Pro 8, and Logic Pro 16, is documented in the support article here: binary-export-format-logic-2.md
Binary Export Format (Version 1)
Logic 2 exports both digital and analog data in binary formats that start with a common header to identify the file type and version.
Key Properties:
- All multi-byte values are in little-endian byte order
- Floating point values are IEEE 754 format
- Current version is 1 (supports gaps and multiple chunks)
- Version 0 files are still used for non-MSO devices
Common Header
All binary export files start with this header:
byte[8] identifier; // Always "<SALEAE>"int32 version; // Current version is 1int32 type; // 0 = Digital, 1 = AnalogData Types:
0- Digital data1- Analog data
Digital Binary Format (Version 1)
The current digital format supports gaps in data and multiple sampling configurations:
byte[8] identifier; // "<SALEAE>"int32 version; // 1int32 type; // 0 (Digital)
uint64 chunk_count; // Number of data chunksfor each chunk in chunk_count: uint32 initial_state; // 0 = Low, 1 = High double sample_rate; // Samples per second double begin_time; // Start time in seconds double end_time; // End time in seconds uint64 num_transitions; // Number of state changes
for each transition in num_transitions: double transition_time; // Time of state change in secondsNotes:
- Each chunk represents a continuous segment of data
- Gaps between chunks indicate missing data, usually due to channels being turned off, but can also occur if USB bandwidth is saturated
- State alternates with each transition (initial_state → !initial_state → initial_state…)
Analog Binary Format (Version 1)
The current analog format supports multiple waveforms with trigger information:
byte[8] identifier; // "<SALEAE>"int32 version; // 1int32 type; // 1 (Analog)
uint64 waveform_count; // Number of waveformsfor each waveform in waveform_count: double begin_time; // Start time in seconds double trigger_time; // Trigger time in seconds double sample_rate; // Samples per second int64 downsample; // Downsample factor uint64 num_samples; // Number of voltage samples
for each sample in num_samples: float voltage; // Voltage value in voltsNotes:
trigger_timeindicates when the trigger occurreddownsamplefactor indicates if data was decimated during export
Python Parsing Examples
Digital Data Parser
import structimport sysfrom dataclasses import dataclassfrom typing import List, BinaryIO, Optional
# ConstantsTYPE_DIGITAL = 0TYPE_ANALOG = 1
@dataclassclass DigitalChunk: """Represents a continuous segment of digital data""" initial_state: int # 0 = Low, 1 = High sample_rate: Optional[float] # Samples per second (None for version 0) begin_time: float # Start time in seconds end_time: float # End time in seconds num_transitions: int # Number of state changes transition_times: List[float] # Times when state changes occur
@dataclassclass DigitalData: """Complete digital data export containing one or more chunks""" chunks: List[DigitalChunk]
def parse_digital_v1(f: BinaryIO) -> DigitalData: """Parse Logic 2 digital binary format version 1"""
# Parse header identifier = f.read(8) if identifier != b"<SALEAE>": raise ValueError("Not a Saleae file")
version, datatype = struct.unpack('<ii', f.read(8))
if datatype != TYPE_DIGITAL: raise ValueError(f"Expected digital data, got type {datatype}")
if version not in [0, 1]: raise ValueError(f"Unsupported version: {version}")
chunks = []
if version == 0: # Version 1 format - single chunk without chunk count chunk_count = 1 else: # Version 1 format chunk_count, = struct.unpack('<Q', f.read(8))
for _ in range(chunk_count): # Parse chunk header initial_state, = struct.unpack('<I', f.read(4))
if version >= 1: sample_rate, = struct.unpack('<d', f.read(8)) else: sample_rate = None
begin_time, end_time, num_transitions = struct.unpack('<ddQ', f.read(24))
# Parse transition times transition_times = [] for _ in range(num_transitions): time, = struct.unpack('<d', f.read(8)) transition_times.append(time)
chunks.append(DigitalChunk( initial_state=initial_state, sample_rate=sample_rate, begin_time=begin_time, end_time=end_time, num_transitions=num_transitions, transition_times=transition_times ))
return DigitalData(chunks=chunks)
def print_digital_data(data: DigitalData): """Print digital data in human readable format""" print(f"Digital data with {len(data.chunks)} chunk(s)")
for i, chunk in enumerate(data.chunks): print(f"\n--- Chunk {i} ---") initial_state_str = 'Low' if chunk.initial_state == 0 else 'High' print(f"Initial state: {initial_state_str}") if chunk.sample_rate: print(f"Sample rate: {chunk.sample_rate} Hz") print(f"Time range: {chunk.begin_time:.6f}s to {chunk.end_time:.6f}s") print(f"Transitions: {chunk.num_transitions}")
# Show state changes current_state = chunk.initial_state print(f" {chunk.begin_time:>15.6f}s: {'Low' if current_state == 0 else 'High'}")
for trans_time in chunk.transition_times: current_state = 1 - current_state # Toggle state print(f" {trans_time:>15.6f}s: {'Low' if current_state == 0 else 'High'}")
# Usage exampleif __name__ == '__main__': if len(sys.argv) != 2: print("Usage: python parse_digital.py <digital_file.bin>") sys.exit(1)
filename = sys.argv[1] with open(filename, 'rb') as f: data = parse_digital_v1(f)
print_digital_data(data)Analog Data Parser
@dataclassclass AnalogWaveform: """Represents a single analog waveform with samples""" begin_time: float # Start time in seconds trigger_time: float # Trigger time in seconds sample_rate: float # Samples per second downsample: int # Downsample factor num_samples: int # Number of voltage samples samples: List[float] # Voltage values in volts
@dataclassclass AnalogData: """Complete analog data export containing one or more waveforms""" waveforms: List[AnalogWaveform]
def parse_analog_v1(f: BinaryIO) -> AnalogData: """Parse Logic 2 analog binary format version 1"""
if datatype != TYPE_ANALOG: raise ValueError(f"Expected analog data, got type {datatype}")
waveforms = []
if version == 0: # Version 0 format - single waveform begin_time, sample_rate, downsample, num_samples = struct.unpack('<dQQQ', f.read(32)) trigger_time = begin_time # No separate trigger time in v0
# Read samples samples = [] for _ in range(num_samples): voltage, = struct.unpack('<f', f.read(4)) samples.append(voltage)
waveforms.append(AnalogWaveform( begin_time=begin_time, trigger_time=trigger_time, sample_rate=float(sample_rate), downsample=downsample, num_samples=num_samples, samples=samples )) else: # Version 1 format waveform_count, = struct.unpack('<Q', f.read(8))
for _ in range(waveform_count): begin_time, trigger_time, sample_rate, downsample, num_samples = struct.unpack('<dddqQ', f.read(40))
waveforms.append(AnalogWaveform( begin_time=begin_time, trigger_time=trigger_time, sample_rate=sample_rate, downsample=downsample, num_samples=num_samples, samples=samples ))
return AnalogData(waveforms=waveforms)
def print_analog_data(data: AnalogData, max_samples: int = 10): """Print analog data in human readable format""" print(f"Analog data with {len(data.waveforms)} waveform(s)")
for i, waveform in enumerate(data.waveforms): print(f"\n--- Waveform {i} ---") print(f"Begin time: {waveform.begin_time:.6f}s") print(f"Trigger time: {waveform.trigger_time:.6f}s") print(f"Sample rate: {waveform.sample_rate} Hz") print(f"Downsample factor: {waveform.downsample}") print(f"Number of samples: {waveform.num_samples}")
# Calculate actual sample period actual_sample_period = waveform.downsample / waveform.sample_rate
print(f"\nFirst {min(max_samples, len(waveform.samples))} samples:") print(f"{'Time (s)':>15} {'Voltage (V)':>12}")
for j, voltage in enumerate(waveform.samples[:max_samples]): sample_time = waveform.begin_time + (j * actual_sample_period) print(f"{sample_time:>15.9f} {voltage:>12.6f}")
if len(waveform.samples) > max_samples: print(f"... and {len(waveform.samples) - max_samples} more samples")
# Usage exampleif __name__ == '__main__': if len(sys.argv) != 2: print("Usage: python parse_analog.py <analog_file.bin>") sys.exit(1)
filename = sys.argv[1] with open(filename, 'rb') as f: data = parse_analog_v1(f)
print_analog_data(data)CSV Export Format
Digital CSV Format
Digital data is exported as a multi-channel time-series showing state changes across all channels:
Time [s],Channel 0 :),Channel 1 :),Ch20.000000000,0,1,X0.125000000,0,0,X0.250000000,1,1,X0.500000000,0,0,10.625000000,1,1,00.750000000,0,1,00.875000000,1,0,11.000000000,X,X,XFormat:
- Header:
Time [s],Channel Name 1,Channel Name 2,... - Time Column: Timestamp in seconds (floating point)
- Channel Columns: Digital state values
Values:
0= Low state1= High stateX= No data (channel disabled or gap in capture)
Notes:
- Each row represents a time point where at least one channel changes state
- Only state transition times are included (not every sample)
Xindicates missing data due to gaps or disabled channels- Time values are relative to the current base time in Logic 2 (usually the start of the capture)
Waveform CSV Format
Waveform data includes trigger timing information along with voltage measurements:
Trigger [s],Time [s],Ch0,Ch10.000000000000,0.000000000000,1200.000000,-200.0000000.062500000000,0.062500000000,1400.000000,300.0000000.125000000000,0.125000000000,-200.000000,-100.0000000.187500000000,0.187500000000,300.000000,400.0000000.000000000000,0.200000000000,,-200.0000000.062500000000,0.262500000000,,300.0000000.125000000000,0.325000000000,,-100.0000000.187500000000,0.387500000000,,400.000000Format:
- Header:
Trigger [s],Time [s],Channel Name 1,Channel Name 2,... - Trigger Column: Time relative to trigger event (floating point seconds)
- Time Column: Time relative to current base time in Logic 2, usually the start of the capture (floating point seconds)
- Channel Columns: Voltage measurements
Notes:
- Each row represents a voltage sample across all channels
- If there is no voltage data for a channel, the voltage value will be empty
- This is shown on the second waveform for Ch0 in the example above
